Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
SoftPhone and Autoattendant Codec Problem..
We have succesfully installed our IP Telephony system and autoattendant works fine with the following config.
dial-peer voice 500 voip
destination-pattern 5..
progress_ind setup enable 3
session target ipv4:xx.x.x.x
dtmf-relay h245-alphanumeric
codec g711ulaw
But with this config SoftPhone does not work remotely over a VPN connection via the internet when you specify that SoftPhone should always use a lowbandwidth codec.
When I remove the "codec g711ulaw" command SoftPhone works perfectly over the VPN connection with the "always use lowbandwidth codec" setting on. But with removing this command we have lost autoattendant.
Any ideas??
Re: SoftPhone and Autoattendant Codec Problem..
The Softphone uses G.729 when you have the always use low bandwidth codec checked. This conflicts with the G.711 codec in your dial-peer. If you do not set the codec in the dial-peer it uses G.729 by default. If your VPN connection does not have enough bandwidth to support G.711, you may have to set the dial-peer as G.729.
voice-gatew(config-dial-peer)#codec ?
clear-channel Clear Channel 64000 bps
g711alaw G.711 A Law 64000 bps
g711ulaw G.711 u Law 64000 bps
g723ar53 G.723.1 ANNEX-A 5300 bps
g723ar63 G.723.1 ANNEX-A 6300 bps
g723r53 G.723.1 5300 bps
g723r63 G.723.1 6300 bps
g726r16 G.726 16000 bps
g726r24 G.726 24000 bps
g726r32 G.726 32000 bps
g728 G.728 16000 bps
g729abr8 G.729 ANNEX-A & B 8000 bps
g729br8 G.729 ANNEX-B 8000 bps
g729r8 G.729 8000 bps
gsmefr GSMEFR 12200 bps
gsmfr GSMFR 13200 bps
I can only choose from the above codecs, I have tried all the g729 codecs but with each one we lose autoattendant??
Strange hey?
What auto attendant are you using? Unity or the Cisco Basic Auto Attendant?
try adding voice-class codec 99 (or some number) in the global config. Under this you add a preference for each codec such as codec preference 1 g711ulaw and codec preference 2 g729r8 or whatever. Then in the dial-peer instead of a codec statement you add the voice-class codec 99. This worked for me when using some old IP phones (the 30 vip) and softphones and 7960's. the old ones only want to use g711 or g723 which stopped the softphones from working.
Fantastic! That did the trick and it works a treat.
Thank you..
195
