SoftPhone does not work over Wireless
I have a strange problem with SoftPhone over Aironet connection.
When my laptop running SoftPhone on a wired connection everything works normally. I can make calls with softphone and both parties hear each other.
The problem is the following:
When the laptop is connected over wireless (Cisco 350 AP, Cisco 350 Card) the laptop user does not receive any sound from the other party.
(It does not receive any packets according to WinXP connection status.)
The laptop users's voice is carried over the network without problem, so the connection is a one way connection.
I have no routing problems. Both wired and wireless connections are in the same subnet, the laptop over wireless still able to connect to every network node.
Any suggestions?
I'm using CM 3.2(3) and Softphone 1.3(3).
Re: SoftPhone does not work over Wireless
I am using softphone over my wireless. I have a 1200 AP and a 350 card. Works great. Make sure under the settings, audio, network audio settings you have the correct IP address of your wireless card.
Hope this helps.
Trae
That was the problem.
Attila
If you use the Automatic Selection it should select the correct IP address when you go either wired or wireless. That is if you loaded the software from a server.
166
