softphone issue
When I'm running the softphone i note that directories doesn't appear and my PC address doesn't appear in : network audio settings --> Automatic Selection
i just find :
Automatic selection --> empty
URL address --> /../getIP.asp
select address --> my PC address
and when i click ok in the same window , the following error message appears:
" Unable to get IP Address from Automatic Selection URL. Please verify Network Audio Settings. Make sure your internet connection (including VPN) is successfully setup before lancing Cisco IP Softphone "
FYI: i havn't VPN connection
be informed that i have download my softphone from my callmanager (where files installation are copied )
How and Where exactely in Callmanager can i fix this issue
Any help will be very appreciated
Thanks a lot
Zahida
Re: softphone issue
as you do not value other NetPro members help, why you keep asking for it?
Re: softphone issue
Please what do you mean by your reply , could you precise more
Thanks a lot
Zahida
96
