Community Member
Softphone Problem
I am running CM 3.2(2c) SP E & ES 63. I am having a problem where the only way I can get the softphone to work is by pointing it to the publisher. If I point it to the subscriber it will not work. This is the second time I have seen this problem. Has anyone else had this problem? Is this functionality or bug?
Frank
Silver
Re: Softphone Problem
Guess, your DC directory on your subcribers are not syncing properly with your publisher. Check this out. Following doc will help you to fix the problem, if there are any issues.
http://www.cisco.com/warp/public/788/AVVID/fixing-dc-dir.html
Community Member
Sorry, I forgot to mention I am doing AD integration.
78
