Community Member
Speed Dial Call Setup Connecton Delay
This is affecting all phones on our Call Manager – Version 4.1. If using speed dial for internal extensions the call connects straight away. If using speed dial for external calls the call takes between 10-15 seconds to connect this is if a # is used or not. I have previously adjusted T302 for when making standard calls but this has no effect on the Speed dials for external calls.
The phones have been updated with the latest firmware.
Is there a Parameter in the Service Parameters I can adjust?
Dominic
Community Member
Re: Speed Dial Call Setup Connecton Delay
Check "Speed Dial await further digits". If set to TRUE, set it to false. But normally, FALSE is the default...
jp
Community Member
Thanks for this reply - the problem has been resolved by changing to False.
Best Regards
Dominic
252
