Speed dials on CME
Is there a way to setup private speed dials on CME (4.0) for each user by logging into a web interface with their userid and password ? I thought there was one, but cant seem to remember what URL should be used to access the user config page (Very similar to http://<callmanager>/ccmuser in a Callmanager environment)
1 REPLY
Re: Speed dials on CME
Never mind, figured it out.
If you have CUE, browse to CUE's ip address. Login using the CUE username and password for a particular user and the following screen appears. See attached.
Sankar.
134
