Speed Dials
We need to populate each user's Speed Dials with the same set of numbers (> 50 each). Is there a way to copy from one user to the next rather than accessing each User Page via the web and adding the same set of Speed Dials?
Erik
Re: Speed Dials
You can access the list of speed dial records of all users by SQL database.
SQL Server Enterprise manager --> CCM03XX --> "speed dials" table
But it is impossible to enter the values directly into this table because of the "pkid" and "msrepl_tran_version" columns.
So, sorry for the bad news :(
Re: Speed Dials
hi,
you use the BAT for this, to add, modify speed dials.
Nicolas
172
