SQL Data
For no reason ,CDR records have stopped being written to the SQL CDR DB. there are no errors replication if ok, any suggestions?
1 ACCEPTED SOLUTION
Re: SQL Data
>>>Verify that "Cisco CDR Insert" and "Cisco CDR Analysis and
Reporting Scheduler" services are running ONLY in the Publisher
Call Manager:
in your publisher callmanager server, go to start > programs >
administration tools > services > verify the status for services
"Cisco CDR Insert" and "Cisco CDR Analysis and Reporting Scheduler".
If they are not "started", please restart them (just right-click
on the service and select "restart").
If "Cisco CDR Insert" and "Cisco CDR Analysis and Reporting Scheduler"
are running also in the subscriber servers, please stop them.
>>>Verify service parameters in callmanager servers (publisher
and subscriber).
--go to ccm admin > service > service parameters > select a callmanager
server from the drop-down list > at "service" please select "Cisco
CallManager" > click on "advanced" > verify that the following
parameters are set to the correct values:
CDR Enabled Flag = True
CDR Log Calls with Zero Duration Flag = True
Call Diagnostics Enabled = True
***Repeat the same procedure for all callmanager servers in your
cluster***
--Now go to ccm admin > service > service parameters > select a
callmanager server from the drop-down list > at "service" please
select "Cisco Data Base Layer Monitor" > verify that the following
parameter is set to the correct value:
Max CDR Records = 1500000
cluster***
--Now go to ccm admin > system > enterprise parameters > verify that
the following parameters are set to the correct values:
CDR File Time Interval (min) = 1
CDR Format = CDRs will be inserted into database
CDR UNC Path = \\\CDR
Local CDR Path = C:\Program Files\Cisco\CallDetail
cluster***
>>>Please go to start > programs > administration tools > services and
restart the following services after hours:
1) Restart service "Cisco database Layer Monitor" on
publisher and subscriber servers.
2) Restart service "Cisco CDR Insert" on the publisher server.
3) Restart service "Cisco CDR Analysis and Reporting Scheduler"
>>>Run SQL querys:
In your publisher server, go to start > programs > SQL Server > Query
Analyzer > SQL Server: (local) ; Select "windows authentication" ;
click on "OK" > select the "ART" database from the drop-down menu. Run
the following queries (just copy and paste the following in the main
window, then click on the "execute query" icon):
delete from Tbl_Load_History
delete from Tbl_Dump_PkID
delete from Tbl_Error_Id_Map
delete from Tbl_Billing_Data
delete from Tbl_Billing_Error
delete from Tbl_Dump_CallDetailRecord
delete from Tbl_Dump_CallDetailRecordDiagnostic
Re: SQL Data
Call Manager:
and subscriber).
cluster***
cluster***
cluster***
>>>Run SQL querys:
Re: SQL Data
that did the trick
thanks
89
