SQL query in ART database for incoming calls
This is the sql statement I am using to pull records from ART database below. After looking at the data pulled I am not getting incoming calls. What colum do I need to include.
select user_id, orig_party_number, orig_called_party_number, final_destination, connect_date, disconnect_date, (disconnect_date - connect_date) as duration, call_type, call_classification from Tbl_Billing_Data where orig_party_number = '50656' and timestamp > '2006-01-03' and timestamp < '2006-01-31'
1 REPLY
Blue
Re: SQL query in ART database for incoming calls
Query the CDR DB directly instead of ART and use this query for inbound:
PARAMETERS [Called Number] Text ( 255 ), [Start Date] DateTime, [End Date] DateTime;
SELECT DateAdd("s",[dateTimeOrigination],"31-Dec-1969 19:00:00") AS [Origin DateTime], IIf(dateTimeConnect<>0,DateAdd("s",[dateTimeConnect],"31-Dec-1969 19:00:00"),DateAdd("s",[dateTimeDisconnect],"31-Dec-1969 19:00:00")) AS ConnectDateTime, DateAdd("s",[dateTimeDisconnect],"31-Dec-1969 19:00:00") AS DisconectDateTime, dbo_CallDetailRecord.callingPartyNumber, dbo_CallDetailRecord.finalCalledPartyNumber, dbo_CallDetailRecord.duration AS Duration
FROM dbo_CallDetailRecord
WHERE (((dbo_CallDetailRecord.callingPartyNumber)<>"") And ((dbo_CallDetailRecord.finalCalledPartyNumber)=[Called Number]) And ((dbo_CallDetailRecord.dateTimeOrigination)>=DateDiff("s",#31/12/1969 19:0:0#,[Start Date]) And (dbo_CallDetailRecord.dateTimeOrigination)<=DateDiff("s",#31/12/1969 19:0:0#,[End Date])));
adignan - berbee
133
