sql replication
what is the procedure to repair broken sql replication between pub and sub. with out rebooting or using DB helper
Blue
Re: sql replication
Re: sql replication
You can also use the DBhelper tool to republish or reinitialize the sql db as well.
Re: sql replication
Do you have a copy of the dbhelper program I can have please?
Hall of Fame Super Red
Re: sql replication
Hi Paul,
Have you checked this out?
If you notice issues with Cisco CallManager failover or notice SQL replication errors in the application event log, check for the DBLHelper.exe file first.
This file is located in the c:\program files\cisco\bin directory. If the file is not currently on the system, open a case with Cisco Technical Support and detail a broken SQL subscription. Use the Cisco TAC Service Request ( registered customers only) tool to open a case.
Note: DBLHelper is only run on the publisher.
From this doc;
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
Hope this helps!
Rob
Please remember to rate helpful posts..........
Re: sql replication
Attached is the DBLHelper
148
