** SQL SP3a qualified **
Just a quick note - QA finished qualifying SQL SP3a and everything worked OK. This is now qualified for use with Unity 3.1(6) and later. It should work find for earlier versions of Unity but wasn't specifically tested with older builds.
Community Member
Re: ** SQL SP3a qualified **
Thanks! Any word on qualification for the latest MS SQL patches? (MS03-031)?
Yes you can install them according to our support policy:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_pre_installation_guide09186a00801245c3.html#19098
Kind Regards
Ullie
101
