SRST and IP Phone Loads on CCM 3.1
Can you overlay the CCM3.1 Phones loads with that recommended for SRST which seem to be CCM 3.0 versions?
Re: SRST and IP Phone Loads on CCM 3.1
I have not tried this. However, note that you should be able to use the loads from CM3.1 at an SRST site and it will work. I have not heard anyone say otherwise.
Note you need at least 12.2(2T) on your IOS gateway for MOH functionality to work.
Currently there's no 12.2 IOS release which supports SRST.
Geert Folens
Network Consultant
Dimension Data Belgium
96
