SRST and IP phone loads
Cisco documents indicates that new ip phone loads is needed inorder to support SRST. I just want to confirm the process to load the ip phone loads.
1. download ip loads from cisco CCO
2. Access CCM console and go in device defaults
3. change the ip phone loads.
Are these steps right? Thanks
Re: SRST and IP phone loads
That's right.
Alternatively, you could download the ip phone load and simply select 1 phone to test it on. ie select a particular phone and change the load setting for that phone. Once you are happy it works, then you could change the phone load under device defaults as you suggested.
NB. I was unaware that you needed a specific phone load, rather you needed to be running a compliant version of ios?? Latest is 12.2(8)T5.
How can I just change one ip phone's load?
In the configuration page for the phone, enter the load you want to run for that particular phone.
All CM3.1 phone loads support SrST
129
