SRST and outbound fast busy tone
I have two remote sites A and B. A's PRI is connecting to DMS-100 switch and B' PRI is connectiong to GDP switch. In SRST mode, both incoming OK, but outbound from A gets fast busy tone. The configuration on both routers are same.
Here is the debug on the router A when make outbound call.
Dec 2 18:03:33 GMT: ISDN Se2/0:23 Q931: TX -> SETUP pd = 8 callref = 0x000B
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, 'XXXXXXX'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '1416XXXXXXX'
Plan:ISDN, Type:Unknown
Dec 2 18:03:33 GMT: ISDN Se2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x
800B
Cause i = 0x82E470 - Invalid information element contents
Dec 2 18:05:19 GMT: ISDN Se2/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x00
39
Cause i = 0x8090 - Normal call clearing
Dec 2 18:05:19 GMT: ISDN Se2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8039
Dec 2 18:05:19 GMT: ISDN Se2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x
Here is some related commands:
interface Serial2/0:23
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
dial-peer voice 100 pots
application mgcpapp
destination-pattern 9T
direct-inward-dial
port 2/0:23
num-exp 78..... 256.....
call-manager-fallback
ip source-address 10.1.1.1 port 2000
max-ephones 50
max-dn 100
keepalive 10
Personally I think its protocol compatibility issue. Any idea for this?
1 REPLY
Silver
Re: SRST and outbound fast busy tone
It's possible the DMS is not liking the called number plan/type. Try the following under the D channel config -
isdn map address . plan unknown type unknown
This will overide the current called number plan and type from ISDN/unknown to unknown/unknown
221
