Community Member
SRST/CME ver4.0 call routing problems
Hello all
I have setup SRST using CME ver 4.0 to utilise the HUnt group functionality of CME. I have configured ephone-dns in the config. The SRST part works fine however external calls cannot be made into this site due to the Virtual Pots dial-peer status for any ephone-dn's configured being up so it is used in call routing and causes a problem for external calls comming in. I know there is a bug ( id CSCse59347) in certain IOS versions which causes the ephone-dn pots dial-peer operational status to remain up even when the phone is not registered to the SRST/CME router. This however only appears to change the status of auto learned ephone-dn's not pre-configured ephone-dn's.
Has anyone out there set this up successfully.
Thanks in advance for help.
regards
shane
151
