SRST does not work for Cisco IP Phone 7912
I'm running IOS 12.4(5) SPSERVICES on a Cisco 3825 (C3825-SPSERVICESK9-M) and have a cluster of two Cisco CallManager version 3.2.
When connectivity to the CallManager cluster is lost, IP Phones 7940 and 7960 successfuly enter fallback mode (SRST) but IP Phones 7912 do not. The Cisco 3825 is both the default-gateway of the IP Phones and the SRST-router.
I checked for bugs on the CCO and, although there are some SRST-related bugs with IP Phones 7912, none of them exactly match this problem.
Is there any limitation regarding SRST support for IP Phones 7912 on CallManager 3.2 or on IOS 12.4(5)?
Thanks in advance.
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.4(5), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Mon 31-Oct-05 21:03 by alnguyen
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
System image file is "flash:c3825-spservicesk9-mz.124-5.bin"
interface Loopback0
ip address 192.168.200.1 255.255.255.255
h323-gateway voip bind srcaddr 192.168.200.1
interface GigabitEthernet0/0
ip address 192.168.1.1 255.255.254.0
call-manager-fallback
max-conferences 24 gain -6
ip source-address 192.168.1.1 port 2000
max-ephones 128
max-dn 256
time-zone 22
time-format 24
1 REPLY
Hall of Fame Super Silver
Re: SRST does not work for Cisco IP Phone 7912
Try using
debug ephone register
to get more info
Chris
168
