Bronze
SRST Fallback Issue
Have the following configuration for SRST router with an E1
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
port 0/3/0:15
dial-peer voice 100 pots
destination-pattern 0T
port 0/3/0:15
dial-peer voice 2000 voip
preference 1
destination-pattern 777..
progress_ind setup enable 3
progress_ind progress enable 8
translate-outgoing calling 1
voice-class codec 10
voice-class h323 10
session target ipv4:172.16.x.x
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
ip qos dscp cs5 media
no vad
dial-peer voice 2001 voip
preference 2
voice-class h323 10
session target ipv4:172.16.x.y
no vad
no dial-peer outbound status-check pots
num-exp 08666777.. 777..
num-exp 8666777.. 777..
num-exp 666777.. 777..
call-manager-fallback
max-conferences 4 gain -6
timeouts interdigit 5
ip source-address 172.17.z.x port 2000
max-ephones 168
max-dn 168 dual-line
When the phones register with the SRST users can make outgoing calls but incomming calls do not work.
At what point when the number comes in via pots does it hand off to the CCM FallBack to match the registered extensions? It matches the VoIP Dial peers ok so is there a preference of them over the ccm fallback?
Re: SRST Fallback Issue
Can you please send the debug isdn q931, sh run and the debug voip ccapi inout
thanks
Green
What are the SRST User extension numbers, how many digits long are they ?
It could simply be a num-exp problem.
Regards, Alex. Please rate useful posts.
Hi ,
In your Call-manager-fallback , you must set also the expression :
dialplan-pattern 1 8666777.. extension-length 5 no-reg
So that you can link the internal number with the external .
Hope that It will help you ....
Olivier
147
