SRST gateway issue - inbound calls failing
I have a test SRST gateway setup (IOS 12.3.14T7) with one FXO line. I can place outbound calls in SRST mode. I cannot place inbound calls.
Attached are my configs. When I give a
"service alternate Default" command application mode, I get the following error:
Blue
Re: SRST gateway issue - inbound calls failing
doesn't the dial-peer need "application mgcpapp"?
you have "service mgcpapp" in the config you've provided.
it looks like this is what the call is looking for from your output you've shown.
gpulos,
application command is deprecated in newer IOS.
You have to use service command.
I ran into the same issue and removed the service mgcpapp. And it worked not sure if the same would apply to your situation, but maybe worth a try. Here is what I have on the dial-peer.
dial-peer voice 81 pots
destination-pattern 81T
incoming called-number .
direct-inward-dial
port 0/3/1:23
If you do the dial-peers like how you have suggested, the router becomes a H323 gateway. I want this gateway to be a MGCP gateway, fallback to H323. When call comes in I can see that MGCP has fall back to H323, but the call fails because some thing is wrong with the Default applcation. Seems like a bug to me.
Howdy Sankar,
You're missing the Global parameter.
http://www.cisco.com/warp/public/788/AVVID/configsrst_mgcpfallback.html
For Cisco IOS® Software Release 12.3(13)T or earlier:
R(config)#call application alternate default
For Cisco IOS® Software Release 12.3(14)T or later:
R(config)#application
R(config-app)#global
R(config-app-global)#service alternate Default
Michael,
Infact I did try the global command yesterday and it did take the service alternate Default command (with out any errors like it did previously).
Even after doing this, inbound calls still fail. If I revert back to h323 mode (no service mgcpapp and no service alternate Default), calls do come in just fine.
With the global and service alternate Default and I get the same syslog error message (check my first post).
Thoughts ??
Hmm. I should've known you'd have done your homework. Sorry about that. :-)
When you force fallback, what does show ccm-manager tell you?
How are you forcing fallback?
Silver
Also, is the ip phone that you are trying to plar to registered to the router? Since the link to the CM is down, that dn would have to have registered as a pots peer for the router to be able to send him the the call, maybe the phone is not failed over yet? The point about how you are forcing fallback might be a good one, I think we had forgotten to force the phones to fail over a few times, with similar results.
Mary Beth
I'm thinking ccm-manager hasn't kicked over fallback mode.
In terms of phone registration, that's a good point for DID circuits, but I'm not so sure in this case. I'd expect dial tone on the inbound call rather than busy since DID is not configured configured on the pots peers. Then, if an unregistered extension is entered by the caller, he should get busy.
Sankar, please correct me if I'm misunderstanding the symptoms - are you getting busy on the initial connect or after the extension is entered?
Michael
Michael / Mary.
Thanks for your valuable time taken to respond to this post. Its working now..
Well here is how i started yesterday. Configured SRST and tested failover and phones do register properly. I am testing failover by simply turning off Callmanager service from Control panel. Like I said before this is still in a test setup. Gateway and Callmanager are in the same lan. So rather than using an ACL, i simply turn the CM service off.
Ah.
I missed the plars - must've been sleepwalking or something...
So Mary was close. The IP Phones were registering with extensions not covered by the plar. The aliases took care of the mismatch.
When you called, the plar rang 1004, but there was no matching ephone. Hence the busy.
BTW,
If you forget a application spelling, you can use the following to verify the correct spelling and capitalization.
VG#do sh call applicatio voice summ
name description
session Basic app to do DID, or supply dialtone.
fax_hop_on Script to talk to a fax redialer
clid_authen Authenticate with (ani, dnis)
clid_authen_collect Authenticate with (ani, dnis), collect if that fails
clid_authen_npw Authenticate with (ani, NULL)
clid_authen_col_npw Authenticate with (ani, NULL), collect if that fails
clid_col_npw_3 Authenticate with (ani, NULL), and 3 tries collecting
clid_col_npw_npw Authenticate with (ani, NULL) and 3 tries without pw
Default Default system session application 2.0
CTAPP Call Treatment Action Application
lib_off_app Libretto Offramp
DEFAULT.C.OLD Obsolete system session application
MGCPAPP MGCP Application
TCL Script Version 2.0 supported.
Call Treatment Action Application - Version 1.0.
Voice Browser Version 2.0 for VoiceXML 1.0 & 2.0 supported.
444
