SRST Help!!
cplatt01
I am in SRST mode and cannot gain access to the PRI.
I am able to dial to the numbes associated with the PRI
I have the following commands in the fallback config:
access-code pri 9 direct-inward-dial
secondary-dialtone 9
Also, incoming calls
jm9393
You need to create a dial peer to direct calls to your PRI such as ...
dial-peer voice 10 pots
destination-pattern 9[2-9]......
port 0/0/0:23 ***use your voice port***
forward-digits 7
You should build a dial peer for each dial pattern available in your area. Post a config and your location if you need more help.
