SRST not registering all DN's on a phone + other issues
I have an installtion using SRST on a 2600 series router (sh ver below). The problem is 2 fold: First I have a 7960 that in normal operating mode shows line 6 as DN 3146, but in SRST mode it shows line 6 as 3135 (a number that was previously programmed for testing). I have removed the SRST config and reloaded the router but it still comes back as 3135 on line 6. Second issue: I have a 7940 that in normal operation has both line 1 and 2 configured, but in SRST mode only the primary line registers.
NOTE: these are the only two phones that are connected at this time.
Here is the sh ver and sh run outputs:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(11)T9, RELEASE SOFTWARE (fc1
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 23-Jun-03 15:43 by cmong
Image text-base: 0x8000809C, data-base: 0x81673E2C
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
****** uptime is 19 minutes
System returned to ROM by reload
System image file is "flash:c2600-is-mz.122-11.T9.bin"
cisco 2620 (MPC860) processor (revision 0x200) with 61440K/4096K bytes of memory
Processor board ID JAD05030IO3 (1543276632)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
2 Voice FXO interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Building configuration...
Current configuration : 2018 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
ip subnet-zero
ip domain name ***********
ip host *******************
ip name-server ************
voice call carrier capacity active
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server ***********
ccm-manager config
mta receive maximum-recipients 0
interface FastEthernet0/0
no ip address
no ip mroute-cache
speed 100
full-duplex
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address *********** 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address **.**.**.** 255.255.255.0
ip helper-address ************
interface Serial0/0
no ip address
no ip mroute-cache
shutdown
ip classless
ip http server
call rsvp-sync
voice-port 1/0/0
timing hookflash-out 50
voice-port 1/0/1
mgcp
mgcp call-agent ********* 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer cor custom
dial-peer voice 9991023 pots
application mgcpapp
port 1/0/0
dial-peer voice 9991123 pots
application mgcpapp
port 1/0/1
dial-peer voice 999100 pots
application mgcpapp
port 1/0/0
call-manager-fallback
ip source-address ********** port 2000
max-ephones 24
max-dn 48
default-destination 3146
access-code fxo 9
voicemail 6000
1 REPLY
Silver
Re: SRST not registering all DN's on a phone + other issues
This does seem like a weird issue. You are however runing a significantly old version of SRST. Can you upgrade to atleast SRST 2.1, (12.2.15T), if the bug is not resolved there either, then I would suggest opening a TAC case for it.
Taimoor
101
