Community Member
SRST not using the prefix command during failover
I have a 2610 running YD3 code, during failover, the prefix command is not prepending any digits into the call and the call fails. Duuring normal operation the prefix command works fine. I was running YD2 but Cisco TAC told me this is fixed with YD3 and it still does not work. Any ideas?
1 REPLY
Community Member
Re: SRST not using the prefix command during failover
hi,
I use YD3 on a 3600 router and i do not have such problems. Are you sure the call matches the correct pots dial-peer?
Yanna
121
