SRST Phone images on 3.1
The release notes state enhanced support via new images. Does anyone know exactly what these enhancements are? I can't find the information on CCO.
Do the default images now support SRST aswell?
Can these images be installed on a 3.0(11) system?
thanks, Mark.
1 REPLY
Re: SRST Phone images on 3.1
This came off the website. The default loads do not support SRST, you will still need the new loads. I am using the currently on 3.0(11) as well as 3.1.
This load addresses the following issues in the D302 load. This load is the D320 load renumbered. Please note the difference between D302 and E302.
Changes in standard Encore load from U301 to C310.
CSCdt67418 - 79xx does not always restart properly.
CSCdt67644 - 79xx does not respond to restart rq if sent during off hook.
CSCdt72768 - 7910 speaker and handset volume bars do not hit max w/in settings.
CSCdt84066 - Changes SCCP TOS value from 5 to 3.
CSCdt65616 - Resetting the phone from CM causes watchdog reset.
109
