11-06-2006 02:00 AM - edited 03-13-2019 03:42 PM
when srst enabled on the phones,calls go through analog lines but failed from e1 line. access code pri does not work.
12.4 ios
11-06-2006 05:24 AM
Can you give more details?
Are inbound calls failing? If so, what do you hear? Do you have phones in fallback with the numbers coming in E1 PRI to receive the call?
You may need translation rules, alias command under fallback to get the numbers to work in fallback if CCM was manipulating the numbers, etc. Does your dial-peer for the PRI have direct-inward-dial on it?
Is this a MGCP or H323 gateway? If MGCP, is MGCP fallback configured correctly for the PRI to fallback and was it in H323 mode at time?
11-06-2006 06:29 AM
hi,
part of the config is below.it's mgcp gateway.
dial-peer voice 9 pots
destination-pattern 9T
direct-inward-dial
port 0/2/0:15
call-manager-fallback
max-conferences 8 gain -6
ip source-address 172.16.0.3 port 2000
max-ephones 40
max-dn 50
access-code pri 9 direct-inward-dial
when i use access-code fxo everything is ok, i can call outside.
but when i use access-code pri , it doesnt work.(note:my pri line works when CCM works.)
IOS:c2800nm-ipvoicek9-mz.124-10.bin
thkns a lot
11-06-2006 08:03 PM
Do inbound / outbound calls work fine without the access-code command? There is a cisco doc (don't have it offhand) that explains that a dial-peer of 9T and an access-code of 9 conflict with one another.
basically what the access-code 9 does is creates a virtual dial peer with 9 as destination pattern which doesn't work well with other dial-peers you created on your own with 9 in them.
You don't need the access-code command.
11-07-2006 11:55 PM
hi
even when i remove acces-code still it doesnt work
incoming called-number 3199...
direct-inward-dial
port 0/2/0:15
max-ephones 40
max-dn 50
transfer-pattern 9T
11-07-2006 12:55 AM
If it works under CCM it indicates that your dial-peer is OK. I notice that you don't have any transfer pattern under call-manager-fallback. Here's a portion from one of my configs that works correctly (NB we use "1" to make an external call. The 9... is for internal extensions)
dial-peer voice 11 pots
tone ringback alert-no-PI
description Dial 1 outgoing
translation-profile outgoing OutBound
destination-pattern 1T
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 0/0/0:15
max-conferences 4 gain -6
ip source-address 192.168.106.1 port 2000
max-ephones 42
max-dn 42 dual-line
transfer-pattern 1T
transfer-pattern 9...
keepalive 10
default-destination 9100
call-forward noan 9100 timeout 12
Hope that helps
Cheers,
John
11-07-2006 11:54 PM
hi again,
unfortunaltey it didnt work.Even if i add transfer-pattern ,still i can not call outside from E1 line. but i can call from fxo lines.
here is the last config :(
direct-inward-dial
port 0/2/0:15
max-ephones 40
max-dn 50
transfer-pattern 9T
thnkx.
11-08-2006 11:49 AM
The only other thing I see is that you don't have an outgoing translation profile on your dialpeer to strip off the leading 9. I think that when you're calling from CCM, it's route plans do that.
You should have something like...
voice translation-rule 1
rule 1 /^9/ // type any unknown
voice translation-profile outBound
translate called 1
then in your dialpeer add....
Although I don't quite see why your FXO would work, unless it's going through a PBX that's stripping the leading 9 for you ????
Cheers,
John
