Blue
SRST Problem
I am having a problem with SRST. Here is what is happening. The WAN fails, phones and gateway go into SRST correctly and inbound/outbound calls work correctly. When the WAN comes back everything goes back to normal and all is good. Now, this is working correctly because the "incoming called-number ." command is under the mgcpapp dial-peers. Here is the problem, if the gateway is reset the mgcpapp dial-peers are re-added but obviously this time without the "incoming called-number ." command. So inbound calls continue to follow the other pots dial-peers and not the mgcpapp dial-peers. I can disable ccm-config but I am hoping there is a better way. I have not had this issue in the past with SRST and I have now tried two different versions of IOS to be safe with the same result. Thoughts? Config is below:
translation-rule 1
Rule 1 ^3726 6
dial-peer voice 14 voip
preference 1
application default
destination-pattern 3726...
translate-outgoing called 1
voice-class codec 1
session target ipv4:192.168.X.X
no vad
dial-peer voice 999001 pots
application mgcpapp
port 0/0:1
dial-peer voice 9 pots
description 7-Digit - SRST
application default
destination-pattern 9[2-9]......
port 0/0:1
forward-digits 7
dial-peer voice 91 pots
description 10-Digit - SRST
application default
destination-pattern 91[2-9].........
port 0/0:1
forward-digits 10
dial-peer voice 911 pots
description 911 - SRST
application default
destination-pattern 9911
port 0/0:1
forward-digits 3
call-manager-fallback
ip source-address 192.168.X.X port 2000
max-ephones 30
max-dn 60
keepalive 10
default-destination 6000
date-format dd-mm-yy
  • Other Collaboration Voice and Video Subjects
1 REPLY
Bronze
Re: SRST Problem
Did you manage to find a solution for this problem? To me it appears as a bug. I am not able find many matching bug in the bug toolkit though!. What versions of IOS did you use btw?
96
