11-01-2006 07:10 AM - edited 03-13-2019 03:37 PM
Hi all..
Need help here....
Two Questions:
First time to set up SRST Tcl, Sort of working... but not 100%.
I dial the AA DID (212 521 4000) from my cell... it connected, after 5 sec, it transfer to pilot extension 4001. If I press "0", it transfered to 4001 at once.
I suspect that I miss a music file to play a greeting. If yes... can anyone point to donwload a right files... coz I couldnt find it.
Second Question:
Can I dial 4000 (AA number) at local site?? I got busy signal for some reason.
Here is my config, please point me out if I doing anything wrong.
application
service srstaa flash:its-CISCO.2.0.1.0.tcl
param operator 4001
paramspace english index 1
paramspace english language en
param pilot 4000
param cm-pilot 4000
paramspace english location flash:
paramspace english prefix en
param aa-pilot 2125214000
dial-peer voice 2000 pots
service srstaa
incoming called-number 2125214000
Ken
11-01-2006 07:18 AM
Ken,
You can download the tar file that says : cme-aa-2.0.1.0.tar
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-iostsp
Use your CCO login to download.
I have seen that the pilot number should match the dnis of the call. So if you telco is sending 10 digits you need to match the pilot with the 10 digits .
Also refer to the help file in flash, after you extract the files to flash for command syntax.
Sankar
PS: please remember to rate posts!
11-01-2006 09:14 AM
Shanky,
The AA greeting is working now after tftp to flash.
I have question from first post... Can I dial 4000 internally??
For example:
Phone 1: 4001
Phone 2: 4002
4001 dial 4000 (I got busy signal), is there anyway to allow 4001 to call 4000 and then play AA greeting????
Ken
11-01-2006 09:35 AM
Yes. you can.
Setup a loopback interface and send the call back to the router itself. Use two dial-peers.
int lo 0
ip add 1.1.1.1 255.255.255.255
dial-peer voice 1 voip
service aa
incoming called-number 4000
no vad
codec g711ulaw
dtmf-relay h245-alpha
dial-peer voice 2 voip
destination-pattern 4000
no vad
codec g711ulaw
Sankar
