Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
SSO for CCM 5.1 TAPI ?
I've installed the CiscoTSP-Version 5.1(1.1) with the CCM 5.1.
My problem is, that i've a w2k domain with passwordchange every 90 days.
So when the user changed the windows password the problem is that they have to change the password also in the TSP-Client. Is there a client or a way for a sso ?
Anonymous
N/A
Re: SSO for CCM 5.1 TAPI ?
Download the TSP plug-in from the CallManager and reinstall it at the Client PC. -If needed reset the End User Password and update the TSP configuration with it. Make sure the user you are using has the device assigned to him via the
CallManager End.
wich plugin do you mean ?
Did you ever get an answer for this.
we are having the same issue. CUCM 6.1 with AD integration. which means that passwors change frequently.
sorry, but i never get an answer.
Could you contact me if you have a way to do it ?
I'm going to change to CCM 6.1 in about 3 weeks.
kind regards, Carsten Radke
228
