Community Member
Standard Call Testing Parameters
hi,
i am asking this quetion sercond time and watng anxiously for the reply.
"i want to know which paramets (e.g PDD, echo,MOS etc) should be considered during VoIP testing.
i will appreciate if any one can provide me the link to site which can give me detailed information about it.
waiting for reponse...thanks"
Community Member
Re: Standard Call Testing Parameters
The question is a little vague. Which parameters should be consider where? On IPSLA-enabled router? There are so many things to look at:
Data sent and received
Jitter
Latency
Lost packets
Call Origination/destination
Date and time
Average Jitter
Congestion
Asymmetric routing
Broadcast traffic
Burst Density
Call failure
Signal
ACOM
ERL
T1/E1 Bearer Channel utilization
Voice gateway type (analog, digital)
Active/recent calls by phone
Active /recent calls by gateway
Device CPU Utilization
Delay
Device did not respond
Down recently
High hop count
Incomplete path
Insufficient bandwidth
Jitter buffer loss
Memory utilization
MOS estimate
No connectivity
No likely causes
Phone down
Recent error
Unstable routing
Community Member
thanks for the reply and let me try to clear my point.
In simple words if i want to test the VoIP qulality of a particulr carrier by making test calls then which scenarios should be followed.Is there any standard document available for such scenarios.
hope i have cleared my point.
thanks....waintg for the reply.
Community Member
There is not a clearly defined standard test plan or use cases to follow. You need to defined that or develop a use case base on best practices.
This link hints at some of these things:
http://www.infosys.com/voip/Quality-Assurance-for-IP-Services.pdf
So if you are using Cisco's VoIP gears on your network, you will look to Cisco's best practices for delivering VoIP. But as of now, I am not aware of a standard body like the IETF that defines testing methodologies for VoIP on a carrier's network.
Hope this helps.
118
