10-05-2006 12:50 PM - edited 03-15-2019 04:34 AM
I have a small office, for about 10 phones. I have 10 Cisco 7960 IP Phones and I have a Cisco Catalyst Switch 3500 Series XL. And I have a firewall-router and a T1 line for this.
Could anybody provide me with a step-by-step explanation on how to set this up or show me a step by step manual?
10-05-2006 01:44 PM
What model of router do you have? Are you running Call Manager Express or what do you plan to use for call control?
10-05-2006 02:43 PM
Well actually all I have is a SonicWALL TZ 170 Unrestricted.... ppl who gave me the equipment - said it's a firewall... I don't have anything else besides that.
10-05-2006 03:01 PM
is Call Control a software, or a physical item that is used to route calls...?
10-05-2006 05:51 PM
You'll have to have something for call control, either a router running CME, server running call manager, or there is a freebie IP PBX system out there that runs on Linux you can download, don't remember the name offhand.
10-05-2006 06:48 PM
My advise of course will be buying a Cisco Product haha, :) (Cisco CallManager Express or Cisco SIP Proxy Server).
But since you are not using any Cisco IOS router nor CSPS is a viable solution, my advise will be of course Asterisk PBX)
I have it running at home integrated with my CCM (obviusly) and works like a charm!
And load to those IP Phones the SIP firmware.
10-06-2006 01:50 PM
Hello Gogasca,
I?m very interesting and tell me where can I find information about the implementacion between CallManager and the Asterisk PBX??
Thank you
10-10-2006 03:57 AM
10-06-2006 07:20 AM
THe server is defently a way to go for me because I have a server computer and I am planning to use that for my call control.
Could you please point me as to where can I get a call manager software for my server??
Another question I have is how do I connect to m y cisco 3500 xl switch? Whenever I connect to a console port with a cross-over cable (http://www.littlewhitedog.com/content-8.html that's where I got the reference on how to make one) it doesn't show a connection at my computer.
10-10-2006 04:19 AM
Maxim,
You need a rollover cable to connecto to a serial port on the PC. More info at:
Catalyst 3500 Series XL Hardware Installation Guide - Connector and Cable Specifications
Hope it helps,
Vitor
