09-04-2002 02:25 PM - edited 03-12-2019 08:38 PM
There is static noise on the IP Phones only on a remote site.Remote Site gateway is a 2620.CCM is 3.1(3a)-SPF.Could it be a problem with the gateway.
Anupama
09-12-2002 12:06 PM
09-12-2002 11:03 PM
There is no VAD in the gateway because there is no dial-peer statement on it.This remote site reaches PSTN via the main site but main site has no static problems.Do I have to check the QOS configurations on both ends.
Thanks a bunch
Anupama
09-13-2002 06:23 AM
Have you try to change the compand-type parameter on voice port configuration ?
Olivier
