Static Noise on IP Phones
There is static noise on the IP Phones only on a remote site.Remote Site gateway is a 2620.CCM is 3.1(3a)-SPF.Could it be a problem with the gateway.
Anupama
Silver
Re: Static Noise on IP Phones
There is no VAD in the gateway because there is no dial-peer statement on it.This remote site reaches PSTN via the main site but main site has no static problems.Do I have to check the QOS configurations on both ends.
Thanks a bunch
Anupama
ola
Have you try to change the compand-type parameter on voice port configuration ?
Olivier
1429
