Community Member
Status monitor and AvCsMgr
Since Unity 3.1.5 has been reboot, I have this message for all ports on the port status monitor page:Software\ActiveVoice\AvCsMgr\1.0\Componentstoload. Any ideas? Everything working fine except this message so I cannot view which greeting is played when a call gets in. AvCsMgr and AvCsgateway services are running.
Thanks in advance
1 REPLY
Re: Status monitor and AvCsMgr
sounds like you've run into this issue:
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCae06777&Submit=Search
If you configure the language in IE to match the default Unity language you wont see that.
96
