STATUSMONITOR - How to "Place Call"
Is someone know how to use "Place Call" option of the StatusMonitor Tool ?
What's the "Call Handling Application [BSTR]" ?
Re: STATUSMONITOR - How to "Place Call"
The StatusMonitor.exe tool is only used for monitoring the port information in real time - it's been replaced in 4.0(3) and later with the much nicer Port Status Monitor. This updated tool works back to 3.1(x) versions of Unity and can be found here:
http://www.ciscounitytools.com/App_PortStatusMonitor.htm
The other functions you see on there are used by internal developers for testing and aren't supported for external user (and, in fact, not all the functions on there even work with all switch configurations). The call handling application is used for outbound notification dial tests (i.e. for pager/phone notification on message triggers) - it's not something you'd want to be fiddling with as a rule.
Thanks for the answer.
Martin
165
