10-11-2005 12:19 AM - edited 03-13-2019 10:48 AM
Hi ,
I have an issue dialing out from an mgcp router using 12.4 version. The issue is that the call rings at the destination phone and the same IP phone too receives the same call. After a while both the phones busy out....very strange
Now using the same configuration when I jst boot the router with IOS version 12.3(14)T all works perfectly well.
Any suggestions ??
Brgds
Renzil
10-17-2005 05:01 AM
Sounds like a bug to me. Which series of routers are using and what's the CCM version?
10-18-2005 03:33 PM
try to put in mgcp package line. i think this is not default in 12.4. in the T train it must be default.. I see that the port actually unregisters:
Oct 11 07:56:51.957: cmapp_mgcpapp_go_down: Setting mgc status to NO_RESPONSE
Oct 11 07:56:51.957: cmapp_host_fsm: New state DOWN for host 0 (10.1.1.3)
Oct 11 07:56:51.961: cmapp_mgr_process_ev_active_host_failed: Active host 0 (10.1.1.3) failed
Oct 11 07:56:51.961: cmapp_mgr_check_hostlist: Active host is 0 (10.1.1.3)
10-18-2005 03:41 PM
Also, I am not seeing the MGCO created dial-peers for the other voice ports. Are all the voice ports configured on the CCM side?
WHat version of IOS exactly, and can you post a debug mgcp packet for a problem call also?
