Stuck with BAT
I just dont get it.
Im trying to put a new Speed Dial for all 100 User we ALREADY have. Using BAT.
So i read this on Cisco:
Adding or Updating Speed Dials in a BAT Template
You can add and update speed dials in the BAT template.
You can designate speed dials for phones and Cisco VGC phones if the Phone Button Template provides speed-dial buttons
Procedure
Step 1 In the Phone or User Device Profile Template Configuration window, choose the template for which you want to add speed dial(s)
Step 2 Click Add/Update Speed Dials in the upper, right corner of the window.
A popup window displays. In this window, you can designate speed-dial buttons for Cisco IP Phones and expansion modules. The phone button template in use for this BAT template determines the number of available speed-dial buttons.
Step 3 In the Speed Dial Settings for Phone area, enter the phone number, including any access or long-distance codes, in the Speed Dial Number field.
Step 4 In the Label field, enter a label that corresponds to the speed-dial number.
Step 5 In the Speed Dial Settings not associated with a button area, you can set abbreviated speed dials for applicable IP phone models by repeating Step 3 and Step 4.
Step 6 Click Update and Close.
BAT inserts the speed-dial settings in the template, and the popup window closes.
So where should i start? Configure->Phones->Insert Phones->Add, view, or modify phone templates,then add new template. Click add speed dial make the change and update? will this do the job? can i roll it back when problem happen?How can i test this for 2 or 3 user first then mad it for all?
Again: this Users/Phones already exist. Some of them Already have configured speed Dials.
Re: Stuck with BAT
BAT inserts the speed-dial settings in the template, and the popup window closes."
Here is a link to the actual doc:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a00803f4f3d.html#wp1207656
Re: Stuck with BAT
Did you read my Post?
I dont think so.
109
