Blue
Subscriber DB Info?
I have been going through the UnityDB trying to find a something that will give me an indication of whether or not a user has setup their mailbox or recorded a "recorded name". They are having problems with Dial by Name in the Directory Handler not working because people are not recording a name. This must be somewhere in the DB I just can't find it.
1 REPLY
Re: Subscriber DB Info?
Check out the Subscriber Information Dump tool, it'll kick out this information for you in a nice CSV format. You'll find the tool in Tools Depot on the desktop or you can download the latest version off www.CiscoUnityTools.com.
the only real way to check it is to look at the "stream path" property off the subscriber and then go make sure that WAV file actually exists in the \commserver\streamfiles\ directory - it'll be easier to just let Subscriber Information Dump do it for you...
86
