Bronze
Supervisor and Skill group in ICM 4.6.2 and CAD 4.2.1.3
Hi ,
I have ICM 4.6.2 and CAD 4.2.1.3 .When the supervisor logs in she can see only the agents logged in and not the skills .I see the skills as N/A.
Is there a way to see all the skill group on the supervisor desktop.
Thanks in advance.
Silver
Re: Supervisor and Skill group in ICM 4.6.2 and CAD 4.2.1.3
The following shows how to set up the skill groups and how to set up the supervisor. http://www.cisco.com/univercd/cc/td/doc/product/icm/icm46/core/confg462/confg_c7.htm
Bronze
Any more suggestions please.
I can see the agents and monitor them. But I cannot monitor the Skill groups.
Thnaks,
I would suspect that the CAD problem you are experiencing might be related to similar issues I encountered with IPCC and CTIOS.
Basically, if the agent is logged in as a primary or secondary to the skill group they participate in, and the script routes the call to the "main" skill group and not to a pri or sec sub-group, then the skill group monitoring won't work...they have to match. If it happens that way in CTIOS desktop, you might be having a similar problem in CAD.
Hope this helps...
235
