Switch Port Configuration for Voice and Data - Best Practice
I need to find out what is the best practice to tipical switch port coniguration which connect to Cisco IP Phone and a PC.
I have the follwoing configuration configured:
interface FastEthernet1/0/12
switchport trunk native vlan 204
switchport trunk allowed vlan 204,205
switchport mode trunk
switchport voice vlan 205
spanning-tree portfast
What do I also need for QoS?
  • Other Collaboration Voice and Video Subjects
Re: Switch Port Configuration for Voice and Data - Best Practice
hello!
you should not have encap dot1q. That command will give you lot of issues. It is true that your port will behave like a dot1q trunk, but it is enough if you configure the voice vlan. so your configs should look like this:
switchport mode access
switch access vlan blah
for QOS, you have to look at the following doc.. It is fairly straight forward:
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a008014f36e.html
THX for the replay,
Can you be little more spacific on what kind of problem I will run into if I configure "encap dot1q"
Thnaks,
I have seen issues where you get an ip address in the data vlan or do not get an ip address at all..
hope that helps.
You cannot just have a "tipical" switchport, it really depends on the type you use.
(i.e. 3550, 3560, 3750)
Some will need a trunk configured, some a access port with a voice vlan on it.
Autoqos will set the correct settings.
also have a look at the QOS and CCM SRND's !
http://www.cisco.com/go/srnd/
490
