Switchs and Routers to provide VOIP solutions.
Witch is the best option in Cisco switchs and routers catalogue to a network with 50 users to implement a VOIP solution?
Best regards
Gustavo Sousa
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Switchs and Routers to provide VOIP solutions.
A 2821 with CME will support up to 52 IP phones, doing a very complete PBX, without the need for external servers or anything else.
Get ISDN for the telco lines, do not use analog lines that are alway a source of trouble. Get a CUE in AIM or NM form if users want voice mail.
For the switch, if you can afford the price, get a a 3560 or 3750 48 ports with PoE. If you can't, get two WS-CE500 24 ports, again with PoE.
Choose the phones as you like better, a good choice is the 7931 that has many buttons and a good lighted display.
That to give you an idea of what you need.
Thanks for the tip it was very helpful.
Best regards
Gustavo Sousa
You're welcome, thanks for the nice rating and good luck!
128
