System Admin
I am running unity 3.0 ie 5.5...the problem I am having is I go to the SA and it opens up but when I try to go into any of the fields on the left hand side like Subscribers it opens up the subscriber but if I try to dig deeper and go to password fild it does nothing but highlight it and if I try to go to account policy or any of the other fields it does nothing but highlight the fields....any thoughts..<br><br>Amy Jones<br>Senior Systems Analyst<br>AAC Associates<br>703-918-6394
Anonymous
N/A
Re: System Admin
Using Internet Explorer 6.0 will cause these problems in the SA. Are you using that version? If so, you'll have to roll back to IE 55, 6.0 isn't supported until Unity 3.1.
Re: System Admin
When I installed the system I used 5.5. The customer put an update tool on the box to automatically go out to microsoft and update everything...I just checked with him and sure enough it upgraded IE to 6.0..thanks for the help
Amy Jones
AAC Associates
703-918-6394
Re: System Admin
We have seen this on systems with IE 6.0. Can you verify the IE version on the machine?
Unity 3.1(1) and onwards support IE 6.0
Anil Verma
Cisco Systems
anilve@cisco.com
90
