T.37 OffRamp Faxing Using Cisco 3825 Router and Unity IP Fax Service
Hi. I already have a Cisco 3825 with 2 T1/PRI with a Cisco CallManager cluster using MGCP. Now the client would like the ability to send faxes from the desktop using the unity ip fax service. I know T.37 OffRamp works with H323 but can I have MGCP on the router for the 2 T1/PRI and then configure H323 for the 3rd T1/PRI to be use for incoming/outgoing fax using T.37??
Any ideas?
Thanks in advanced,
-Jose
  • Other Collaboration Voice and Video Subjects
1 REPLY
Silver
Re: T.37 OffRamp Faxing Using Cisco 3825 Router and Unity IP Fax
I don't think you can have MGCP for this to work.
182
