T1 CAS 12 channels not coming up
Folks,
I have a 2811 that i recently hooked up to a partitial T1 for voice (12 channels). The controller is up, but the channels are idle hung or busied out. The t1 connects to a channel back.
Here is the config, do i need some additional commands for clocking???!
ip cef
ip dhcp excluded-address 10.1.6.1 10.1.6.10
ip dhcp excluded-address 172.16.6.1 172.16.6.10
ip dhcp pool Data
network 172.16.6.0 255.255.255.0
default-router 172.16.6.1
domain-name federalrealty.com
dns-server 172.16.2.21
ip dhcp pool Voice
network 10.1.6.0 255.255.255.0
option 150 ip 10.1.6.1
default-router 10.1.6.1
no ip domain lookup
--More-- ip domain name federalrealty.com
ip multicast-routing
ip ips po max-events 100
no ftp-server write-enable
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
--More-- !
controller T1 0/1/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-12 type e&m-wink-start
Blue
Re: T1 CAS 12 channels not coming up
You would normally set the router to clock the T1 for a channel bank -- unless the channel bank is connected to an accurate clock source, which usually only happens in COs.
clock source internal
What kind of cards are in the channel bank? You may need FXO or FXS signalling rather than E&M.
Silver
There doesn't appear to be any config for your voice-port, maybe you missed it off! Try shutting down the voice-ports and bringing them back-up.
113
