T1 CAS inbound dialing using H323
Does anyone have an example of a config of an IOS gateway for use with Call Manager 3.1.2 for inbound dialing through t1 cas. The number that outside callers will dial is a 1800 number. Once the call comes in it will need to be routed via operator extension within call manager. Any help would be much appreciated.
Martin
Re: T1 CAS inbound dialing using H323
you need to do a number expansion. it is configured in the general config leval. so for example if the telco is delievering 4 digits like 0034 then it would be.
num-exp 0034 0
dial-peer voice 4 voip
dest-pat 0
session target ipv4:x.x.x.x
so the first part of the number expansion what ever the telco is delivering the second part is the number of the operator it could be her 4 digits if you do not have a translations pattern in cm.
hope this helps.
scott
I've done this with PLAR before. Ex:
dial-peer voice 100 voip
destination-pattern 0
voice-port 1/0:0
connection plar 0
131
