TCL 2.0 and vxml hybrid
I have a problem with my vxml output. According to the debug log, the result is right but the are extra vxml process that change the output. Below are my tcl/vxml code :
proc act_GetANIList { } {
global param1
global Result
global pinN
global accountN
global account
global pin
global aniNo
global paramarray
set vxmlScript {<vxml version="2.0"><form><var name="accNo" expr="com.cisco.params.accountN"/><var name="userPwd" expr="com.cisco.params.pinN"/><block><cisco-puts>DEBUG:VXML</cisco-puts><submit expr="'http://anilistservlet'" method="get" namelist="accNo userPwd"/><exit namelist="Result"/></block></form></vxml>}
set paramarray(accountN) $account
set paramarray(pinN) $pin
puts "\n\tAccount no is $account , pin is $pin\n\n"
leg vxmldialog leg_incoming -u $baseURI -v $vxmlScript -p paramarray
puts "VXML END"
proc act_SearchAniStatus { } {
global param1
global param2
global param
global paramarray
global pin
global account
global ani
global prompt_ANI
set exp_ev vxml.session.complete
set ev [infotag get evt_vxmlevent]
if {$ev != $exp_ev} {
media play leg_incoming _my_no_aaa.au
fsm setstate CALLDISCONNECT
return
set status [infotag get evt_status]
if {$status != "vd_000"} {
return
set eventParam [infotag get evt_vxmlevent_params paramarray]
for {set i 0} {$i < [llength $eventParam]} {incr i} {
set [set value [lindex $eventParam $i]] $paramarray($value)
set Result $paramarray($value)
set cnt [expr $i + 1]
append prompt_ANI "_my_[set cnt].au %s1000 " "_zero.au " $option_prompt " %s1000 "
set paramarray($value) ""
if {$Result == "3"} {
media play leg_incoming _Not_registered_any_phone.au
} elseif {$Result == "2"} {
media play leg_incoming _Failed.au
} else {
_Registered_phone_no.au $prompt_ANI
media play leg_incoming _Registered_phone_no.au $option_prompt
set prompt_ANI ""
return
The output is :
.Jan 17 13:15:25.185: <var>: namep=aniNo1 expr=0122222222
.Jan 17 13:15:25.185: //-1//VXML:/vxml_expr_eval: expr=var aniNo1=0122222222
.Jan 17 13:15:25.185: <var>: namep=aniNo2 expr=0192505246
.Jan 17 13:15:25.185: //-1//VXML:/vxml_expr_eval: expr=var aniNo2=0192505246
.Jan 17 13:15:25.189: <var>: namep=aniNo3 expr=0361565224
.Jan 17 13:15:25.189: //-1//VXML:/vxml_expr_eval: expr=var aniNo3=0361565224
.Jan 17 13:15:25.189: vxml_counter_reset:
.Jan 17 13:15:25.189: //-1//VXML:/vxml_formitem_select: Status=VXML_STATUS_OK,
.Jan 17 13:15:25.189: //-1//VXML:/vxml_formitem_select: AsyncStatus=VXML_STATUS_OK
.Jan 17 13:15:25.189: //-1//VXML:/vxml_expr_eval: expr=_in76='defined'
.Jan 17 13:15:25.189: //-1//VXML:/vxml_block_proc:
.Jan 17 13:15:25.189: <block>:
.Jan 17 13:15:25.189: //-1//VXML:/vxml_item_attrs_proc: name=_in76
.Jan 17 13:15:25.189: //-1//VXML:/vxml_exit_proc:
.Jan 17 13:15:25.189: <exit>:
.Jan 17 13:15:25.189: //-1//VXML:/vxml_nmtokens_proc: name=aniNo1 name=aniNo2 name=aniNo3
.Jan 17 13:15:25.189: //-1//VXML:/vxml_leave_scope: scope=8
.Jan 17 13:15:25.189: //-1//VXML:/vxml_vapp_terminate: vapp_status=0 ref_count 0
.Jan 17 13:15:25.189: //-1//VXML:/vxml_vapp_terminate: exitstr=aniNo1=21570706,aniNo2=192505246,aniNo3=63367828
.Jan 17 13:15:25.189: //-1//VAPP:/vapp_terminate:
.Jan 17 13:15:25.189: //-1//VAPP:/vapp_session_exit_event_name: Exit Event vxml.session.complete
The output change from :
namep=aniNo1 expr=0122222222 to exitstr=aniNo1=21570706
and
expr=var aniNo3=0361565224 to aniNo3=63367828
TQ.
107
