TCL IVR script: Problems making a simple call.
I'm trying to get a simple TCL IVR script running on a on a 3745 with IOS IP Plus 12.3(1) , but I am not able to setup a call.
The important lines from the tcl-script:
leg proceeding leg_incoming
leg setup 166 callInfo leg_incoming <-- this line generates the error
Here is the outgoing voice peer from the running config.
dial-peer voice 166 voip
destination-pattern 1..
session target ipv4:192.168.100.93
codec g711ulaw
This h323 peer is a simple Netmeeting client on my PC.
Here is the debug output (debug voice ivr all):
6d01h: Destination SetupPeer cid(242), destPat(166), match(1), prefix(), peer(63BE064C)
6d01h: //-1//PCM :HN1F3772A4:/DNSetupPeer: cid(242), can't gateway with peer tag(166)
6d01h: //-1//PCM :HN1F3772A4:/DNInitiate: DestinationSetupPeer Failed.
6d01h: //-1//PCM :HN1F3772A4:/DNCleanup: Terminate=TRUE Status DN_CANTGATEWAY
Any suggestions would be appreciated. It would also be helpful If you know a place where to get simple script examples.
Daniel Steinke
144
