tcl script for outgoing call leg
I am trying to load a cisco provided script on my as5300 named ring_call.1.1.3.tcl which comes from a zip file tclware.1.2.3. The script says that it was written for an incoming did call and it works fine for an incoming did call, however i loaded the same script to be used for an outgoing call, the script run but it skips the audio prompt playout and continues my call. I was supposed to use this script to fill the post dialing delay issue that i am encountering on my e1/r2 line.
Anyway, does anybody tried this configuration and edited the script and make it work. If so, can i have any information or other script available that i can use or similar that will suffice this requirement.
Thanks in advance for any info.
Here is the error message in debug voip ivr that i have captured.
App ring, callID 107 Error: can play prompt only on telephony call legs.
Joel
1 REPLY
Bronze
Re: tcl script for outgoing call leg
146
