TDM switch E1 and Polycom RMX1500
Hi guys,
i need to passthru 4 channel of a Telco PRI (15 bi-directional channels). I've two E1 dual-port (Cisco 2811 with 72 DSP PVDM) card and this is the configuration of Serial interfaces:
card type e1 0 0
card type e1 0 3
network-clock-participate wic 0
network-clock-participate wic 3
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
  rel1xx disable
  header-passing
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
codec preference 4 g729r8
controller E1 0/0/0
pri-group timeslots 1-16
controller E1 0/0/1
controller E1 0/3/0
clock source internal
pri-group timeslots 1-6,16
controller E1 0/3/1
interface Serial0/0/0:15
description ** PRI 061xxxx **
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 4000
isdn incoming-voice voice
isdn send-alerting
no cdp enable
interface Serial0/0/1:15
description ** PRI 065xxxx **
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/3/0:15
description ** TRUNK TO RMX1500 **
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn sending-complete
no cdp enable
there are the dial-peers:
dial-peer voice 1 pots
description *** PEER IN 061234***
incoming called-number 61234...
direct-inward-dial
dial-peer voice 2 pots
description *** PEER IN 65678 ***
incoming called-number 65678...
direct-inward-dial
dial-peer voice 3 pots
description *** ROUTE TO RMX1500 ***
destination-pattern 65678998
port 0/3/0:15
forward-digits all
dial-peer voice 4 pots
incoming called-number 065678998
direct-inward-dial
port 0/3/0:15
dial-peer voice 305 voip
preference 1
destination-pattern 65678T
progress_ind setup enable 3
session protocol sipv2
session target ipv4:10.100.253.7
session transport udp
dtmf-relay rtp-nte
no call fallback
codec g711ulaw
no vad
dial-peer voice 2000 pots
description *** OUT CALL ***
preference 1
destination-pattern .T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0:15
when I call 065678998, the call is routed on voice port 0/3/0:15 (where RMX is attached with E1 cross-cable) but the call is terminated by the other endpoint (RMX) and sent to the voip dial-peer (that has T parameter).. i'm still investigating if it's an issue of the RMX, because on the q931 debug the call seems terminated in a normal way
I can also not make outbound call from the RMX via E1. Doing a debug of dial-peer when the outbound call is placed, there is not match
I get a B-channel up on the Serial0/3/0:15 (coming from RMX), but the router doesn't "route" the call to the other voice-card (Serial0/0/0:15 Telco PRI)
How to solve?
Many thanks!
there is more logs in debug q931
Mar 27 15:58:21.449: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 06xxxxx
Mar 27 15:58:21.453: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Called num 65678998
Mar 27 15:58:21.453: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x009F
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8283
VGW01# - Origination address is non-ISDN
Calling Party Number i = 0x2183, '06xxxxx'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '65678998'
Mar 27 15:58:21.477: ISDN Se0/3/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x809F
Mar 27 15:58:21.513: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x809F
Cause i = 0x8090 - Normal call clearing
Mar 27 15:58:21.517: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x009F
Mar 27 15:58:21.533: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x809F
ok after a long night, i can made voice call from and to the RMX
now the problem seems on video isdn call..
when try to call a Polycom test number, the other call are rejected with this debug
GW01#
Mar 28 08:39:43.426: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2701
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Calling Party Number i = 0x80, '990'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '00441753723849'
Sending Complete
Mar 28 08:39:43.450: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xA701
Mar 28 08:39:45.614: ISDN Se0/3/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xA701
Progress Ind i = 0x8188 - In-band info or appropriate now available
Mar 28 09:39:46: %ISDN-6-CONNECT: Interface Serial0/0/0:14 is now connected to 00441753723849 N/A
Mar 28 09:39:46: %ISDN-6-CONNECT: Interface Serial0/3/0:0 is now connected to 990 N/A
Mar 28 08:39:46.258: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8  callref = 0xA701
Mar 28 08:39:46.270: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x2701
Mar 28 08:39:51.886: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2801
Standard = CCITT
Channel ID i = 0xA98382
Exclusive, Channel 2
Sending Complete
Mar 28 08:39:51.906: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xA801
Mar 28 08:39:52.406: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2901
Standard = CCITT
Channel ID i = 0xA98383
Exclusive, Channel 3
Called Party Number i = 0x80, '00441753723645'
Sending Complete
Mar 28 08:39:52.418: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xA901
Cause i = 0x82AC - Requested circuit/channel not available
Mar 28 08:39:52.906: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2A01
Standard = CCITT
Sending Complete
Mar 28 08:39:52.918: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xAA01
Mar 28 08:39:53.414: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2B01
Standard = CCITT
Called Party Number i = 0x80, '00441753723853'
Sending Complete
Mar 28 08:39:53.430: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xAB01
VGW01#
Mar 28 08:39:53.938: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2C01
Standard = CCITT
Sending Complete
Mar 28 08:39:53.954: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xAC01
Mar 28 09:39:54: %ISDN-6-CONNECT: Interface Serial0/0/0:13 is now connected to 00441753723849 N/A
Mar 28 08:39:54.838: ISDN Se0/3/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xA801
Mar 28 09:39:54: %ISDN-6-CONNECT: Interface Serial0/3/0:1 is now connected to 990 N/A
Mar 28 08:39:54.854: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8  callref = 0xA801
Mar 28 08:39:54.866: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x2801
Mar 28 08:40:07.479: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x2701
Mar 28 08:40:07.483: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x2801
Mar 28 09:40:07: %ISDN-6-DISCONNECT: Interface Serial0/3/0:0  disconnected from 990 , call lasted 21 seconds
Mar 28 09:40:07: %ISDN-6-DISCONNECT: Interface Serial0/3/0:1  disconnected from 990 , call lasted 12 seconds
Mar 28 08:40:07.491: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xA701
Mar 28 08:40:07.491: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xA801
Mar 28 09:40:07: %ISDN-6-DISCONNECT: Interface Serial0/0/0:14  disconnected from 00441753723849 , call lasted 21 seconds
Mar 28 08:40:07.507: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x2701
Mar 28 08:40:07.515: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x2801
Mar 28 09:40:07: %ISDN-6-DISCONNECT: Interface Serial0/0/0:13  disconnected from 00441753723849 , call lasted 12 seconds
Mar 28 08:40:36.535: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2D01
Standard = CCITT
Sending Complete
Mar 28 08:40:36.559: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xAD01
Mar 28 08:40:38.583: ISDN Se0/3/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xAD01
Mar 28 09:40:38: %ISDN-6-CONNECT: Interface Serial0/0/0:14 is now connected to 00441753723849 N/A
Mar 28 09:40:39: %ISDN-6-CONNECT: Interface Serial0/3/0:0 is now connected to 990 N/A
Mar 28 08:40:39.131: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8  callref = 0xAD01
Mar 28 08:40:39.371: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x2D01
Mar 28 09:40:44: %ISDN-6-CONNECT: Interface Serial0/0/0:2 is now connected to 141275158 N/A
Mar 28 09:40:44: %ISDN-6-CONNECT: Interface Serial0/0/0:3 is now connected to 3355385688 N/A
Mar 28 08:40:44.727: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2E01
Standard = CCITT
Sending Complete
Mar 28 08:40:44.747: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xAE01
Mar 28 08:40:45.227: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2F01
Standard = CCITT
Sending Complete
Mar 28 08:40:45.239: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xAF01
Mar 28 08:40:45.747: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x3001
Standard = CCITT
Sending Complete
Mar 28 08:40:45.759: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xB001
VGW01#
Mar 28 08:40:46.307: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x3101
Standard = CCITT
Sending Complete
Mar 28 08:40:46.563: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xB101
Mar 28 08:40:46.807: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x3201
Standard = CCITT
Sending Complete
Mar 28 08:40:46.827: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xB201
the E1 telco is a 15 channels in/out, E1 connected to the RMX is configured with 1-31 timeslots
hope someone can help me
673
