Telephony numbering plan type
is there any way to configure Telephony numbering plan type from Unknowns to National on router?
I am useing 3360 with PRI connected to Alcatel 4400.
best regards
|----0001 |Numbering Plan Id |ISDN/Telephony numbering Plan E.164 |
|-000---- |Type of Number |Unknown
1 ACCEPTED SOLUTION
Re: Telephony numbering plan type
You'll need the isdn map command of the serial interface:
e.g
interface serial1/0:15
isdn map address .* plan isdn type national
.* is a regular expression that matches all numbers - set the plan and type as appropriate.
Hope this helps,
Justin
1 REPLY
e.g
Hope this helps,
Justin
255
