05-10-2006 06:17 AM - edited 03-13-2019 01:13 PM
We try to do works the Ip Communicator with Cisco VPN Client.
We don't have a problem with the IPsec connection that works verry well. we can reachable the CCME from the LapTop with the Cisco VPN Client but the Ip communicator can't register.
Any body have an suggestion , we be appreciate the tips.
05-10-2006 06:44 AM
Make sure that IP Communicator can get the TFTP server through DHCP using option 150 or 66 (preferably 150) or that you have manually configured the TFTP server in IP Communicator as shown in the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps5475/products_tech_note09186a008026d36f.shtml
Hope this helps. If so, please rate the post.
Brandon
05-10-2006 07:40 AM
Thanks for your advice but we try to do Ip-Communicator with Cisco Call Manager Express version 4.0.(x) not with Call Manager (Windows).
If you have more information to share with us , we appreciate them.
Best Regards
05-10-2006 11:01 AM
Obviously define the ip address of the CCME 4.0 in the IP Communicator.
I had a registration problem with the same setup, and it turned out that it was because I had NAT enable on the CCME. Once I removed NAT, (the data was the outside interface, the voice was the inside), then the CIPC registered OK.
Also, you need to ensure that the ACLs for your VPN also allow for the voice network.
05-11-2006 01:57 PM
I attached you the topology of connection we try to do.
We have all IP permited betwen both lands.
When VPN client connected the router give them an IP address scope of 172.16.1.x and the router is the same that runn CCME and the local ip address is 192.168.1.1
I hope you understand my poor english thanks.
05-10-2006 11:33 AM
You will still need to define the TFTP server address even with CME. Please see the following link for instructions more explicitly for CME.
Brandon
05-11-2006 01:47 PM
