02-09-2006 09:29 PM - edited 03-13-2019 12:08 PM
I am using CCM 4.0. Presently for the last couple of days that there are intermittent TempFail error coming in IP Phones and after some time automatically goes off.
Can anyone suggest what might the exact reason for this.
Thanks in Advance.
02-10-2006 02:20 AM
do a search on the the error for this forum and you should get some hits..basically, one of the older post states:
When the phone says temp fail it means that the RTP stream is still up but signaling is down.
For example you wouldn't be able to place the call on hold but the conversation could continue
02-10-2006 06:00 AM
Thanks for your input.
But is there any specific reason why this happens.
Any workaround which anyone can specify.
Thanks in advance.
02-11-2006 05:52 AM
I have seen this before. This only seems to happen when the phones are registered with a Callmanager which is across the WAN. What is your topology? Does this happen when all Callmanager servers and ip phones are on the same LAN?
Sniffing the network would help to see if there is any connectivity issues. As this is intermittent, it is really hard to track down.
Veera
02-13-2006 06:27 AM
The temporary failure message is used to indicate to the user on the phone that supplementary services for the active call are no longer availiable because callmanager no longer has the ability to
manipulate the preserved call.
Is the system need transcoder or hardware conference for different codec?
Please make sure the resources are enough for the voice gateway, especially when the phone with G.729 codec make outside call to PSTN phone sets. The voice gateway need extra DSP resources.
