Community Member
termination in cisco dead air
When the call is terminated, we are having dead air and in a few seconds the calls gets cleared. Cisco as5300 E1 is connected from a Channel bank using r2-digital. In this case, what are the things I need to look closer, or modify to solve the problem. Below is dial peer and voice port config.
voice-port 0:0
translate called 1
echo-cancel coverage 16
compand-type a-law
cptone SA
dial-peer voice 10 pots
destination-pattern .T
port 0:0
prefix ,,
dial-peer voice 200 voip
huntstop
destination-pattern 00T
voice-class codec 1
session target ras
dtmf-relay cisco-rtp
ip qos dscp cs5 media
dial-peer voice 20 pots
incoming called-number .
direct-inward-dial
port 0:0
dial-peer voice 19 voip
destination-pattern 9663T
session target ras
dial-peer voice 1 pots
translation-profile incoming prefix
dial-peer voice 101 pots
direct-inward-dial
port 0:0
1 REPLY
Silver
Re: termination in cisco dead air
The configuration looks good. Are you seeing any errors on the console. If yes what are the errors that you see. Also try enabling the debug commands. This may help in troubleshooting this issue.
134
